Last visit was: Tue Sep 16, 2025 8:43 pm
It is currently Tue Sep 16, 2025 8:43 pm
subOctavo: a 3-operand RISC
Myron Plichota
Code: * subOctavo is a single-thread mutation of Eric LaForest's Octavo 3-operand RISC concept at https://fpgacpu.ca. * All code, data, and IO "exist" within a single 1024x36-bit addressable space. * asm.cmd assembles <yourchoice.py> and generates x.hex, the 2-port RAMs image. * ivsim.cmd simulates subOctavo.prj and generates subOctavo.log.
* Prerequisite development tools: 1) Python3, e.g. https://www.python.org/, to implement the 2-pass assembler that generates x.hex. 2) Icarus Verilog, e.g. http://bleyer.org/icarus/, to define subOctavo and simulate x.hex.
* The characteristic width of the i instruction field is 4 bits. * The characteristic width of the program counter, and d, a, and b instruction fields is 10 bits. * The bit aggregate of a 36-bit instruction is {i, d, a, b, 2'b00}.
* The i, a and b 2-port RAMs are initialized with x.hex. * The i, a and b 2-port RAMs are read from on negative clock edges. * The i, a and b 2-port RAMs are written to at the d address on positive clock edges. * The critical path is between the negative and positive clock edges, suggesting a clock duty cycle of < 50%.
* The address 0 is reserved for a safe destination, namely 'trash'. trash might be used as a scratchpad. * The address 1 is the program counter reset value, namely 'reset', the first instruction of all programs. * The address 0x3ff points to the read-write parallel output port. * The address 0x3fe points to the read-only parallel input port. * The address 0x3fd points to the read-only free-running timer.
* Non-jump instructions treat the a-field as a pointer like the d and b fields. * Jump instructions treat the a-field as a 10-bit constant (#a).
* Any non-jump instruction with the destination address of trash suffices as a no operation. * The "standard" subOctavo nop() is {band, trash, trash, trash, 2'b00}, which encodes to 36'h300000000.
* The instruction register and program counter stack are updated on positive clock edges. * pc[0] refers to the top of the program counter stack, which is the active program counter. * With a program counter stack register array of [0:7], calls may be nested up to 7 levels. * Jumps involve 1 following instruction (which will execute) due to the pipeline latency. * Jumps write 0 to trash.
* 36-bit instruction summary: add {4'h0, d, a, b, 2'b00} d = a + b; pc[0]++ sub {4'h1, d, a, b, 2'b00} d = a - b; pc[0]++ mul {4'h2, d, a, b, 2'b00} d = a * b; pc[0]++ band {4'h3, d, a, b, 2'b00} d = a & b; pc[0]++ bor {4'h4, d, a, b, 2'b00} d = a | b; pc[0]++ bxor {4'h5, d, a, b, 2'b00} d = a ^ b; pc[0]++ srl {4'h6, d, a, x, 2'b00} d = {1'b0, a[35:1]}; pc[0]++ sra {4'h7, d, a, x, 2'b00} d = {a[35], a[35:1]}; pc[0]++ ror {4'h8, d, a, x, 2'b00} d = {a[0], a[35:1]}; pc[0]++ jze {4'h9, trash, a, b, 2'b00} d = 0; if (b == 0) pc[0] = #a else pc[0]++ jnz {4'ha, trash, a, b, 2'b00} d = 0; if (b != 0) pc[0] = #a else pc[0]++ jpo {4'hb, trash, a, b, 2'b00} d = 0; if (b >= 0) pc[0] = #a else pc[0]++ jne {4'hc, trash, a, b, 2'b00} d = 0; if (b < 0) pc[0] = #a else pc[0]++ jmp {4'hd, trash, a, x, 2'b00} d = 0; pc[0] = #a jsr {4'he, trash, a, x, 2'b00} d = 0; pc[7:2] = pc[6:1]; pc[1] = pc[0]+1; pc[0] = #a ret {4'hf, trash, x, x, 2'b00} d = 0; pc[0:6] = pc[1:7] * By convention, a don't-care field (x) is encoded as 0. See asm.py.
* Zipped subOctavo source is at https://drive.google.com/file/d/1WQC-dlEbdtbmipySzIj6YDEAGJhdybpq/view?usp=drive_link. * The x-series of .py files reflects the author's subOctavo programming learning curve. * x1.py crawls out of the primordial goo. * x15.py solves integer square roots (with remainders). * Author contact: MyronPlichota@gmail.com.
Sat Feb 22, 2025 5:53 am |
quite a remarkable machine!
I suppose the original 8-threaded machine achieved its high performance by getting 8 clock cycles of latency?
Sun Feb 23, 2025 7:40 am |
Myron Plichota
I concur.
Octavo jumps do not involve any delay slots, unlike most other 3-operand RISCs. However, generating 8-threaded code to exploit this strength is a black art.
Sun Feb 23, 2025 2:09 pm |
Yes, it seems to me the designer did feel that the clever hardware design had forced a need for extremely clever software.
I don't quite understand the A and B parts of memory - is it really true that each of the two operands must come from different parts of memory?
Sun Feb 23, 2025 4:57 pm |
Myron Plichota
The i, a, and b 2-port RAMs are separate instances of the 1024x36-bit ram_2p_nr_pw module. The i, a, and b RAMs write addresses are driven by the instruction d field. The i RAM read address is driven by the program counter. The a RAM read address is driven by the instruction a field. The b RAM read address is driven by the instruction b field.
Mon Feb 24, 2025 4:05 am |
Aaah - so this is really a single logical memory implemented as three memories with the same contents?
Mon Feb 24, 2025 8:20 am |
Myron Plichota
Just so!
Mon Feb 24, 2025 10:22 am |
