Last visit was: Fri Dec 12, 2025 9:03 pm
It is currently Fri Dec 12, 2025 9:03 pm
 [ 246 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17
 Qupls (Q+)
With a project your size
how do check for the stupid little errors?
I run something called lint on the code. It checks for all kinds of mistakes. Then I also run synthesis to get the size of things.
I spot a lot of the little errors while editing the code. There are bound to be errors yet undetected.
I work on things incrementally, and have ported code from other projects that was working. I try not to do too much at once without running some sort of test.
Doing diffs helps too.
I have lots of experience by now and that helps. I tend to avoid common mistakes.
Re-did micro-op loading into the decode stream. The number of micro-ops allowed per instruction was increased to 48 from eight. That is enough micro-ops to cover more complex sequences like float divide and reciprocal. The synthesize size is just slightly less than it was before, while at the same time allowing many more micro-ops per instruction.
I have been busy reducing the size of the core. A whopping 60k LUTs has been removed, without changing functionality. I got the 23,000 LUT ROB down to about 18,000.
Did a lot of work on the micro-op (instruction) decoder, converting about a dozen modules for Qupls4.
Got register r0 working as a general-purpose register now, except when it is used in an address calculation.
Rbase = r0 bypasses to 0
Rindex = r0 bypasses to 0
Bypassing r0 for both base and index allows absolute addressing mode.
Otherwise r0 is a general-purpose reg.
Register fields can be used as small or large constants for most instructions. There is not much need to bypass r0 to 0.
Added a LOADI instruction so that loading a constant into a register is possible while r0 is non-zero. An ADD instruction was being used before to load constants.
Added two opcodes to allow instruction pointer relative addressing for loads and stores.
Updated some of the documentation again.
Sun Dec 07, 2025 2:55 am WWW
Online
Very good!
Sun Dec 07, 2025 1:13 pm
Reduced the size of the core again, due to work on the instruction dispatcher.
Figured out what was causing the tools to take a long time to synthesize. It was in the instruction dispatcher. There were a way, way too many muxes. It worked previously because data structure sizes were smaller, and there were fewer functional units. I managed to re-write things in a better fashion and now the instruction dispatch is much smaller. There are some limitations however.
Previously there was no limitation on instruction dispatch other than a max of four per clock cycle. Now, there are restrictions on which functional units can be issued instructions in the same clock cycle. For instance, both a multiply and a divide cannot be issued in the same clock cycle as they are sharing a dispatch slot now. But I managed to increase the number of dispatch slots to five.
Tue Dec 09, 2025 6:16 am WWW
Does scaling where you multiply and then divide work ok? tax 7.25 %
pennys = (pennys * 725) / 100
Tue Dec 09, 2025 9:04 am
In theory it should work. It will still do all the instructions eventually, but it may not be in the first cycle that it is encountered. If a divide and multiply happen at the same time, it will choose to do the divide to queue first as that can take many clock cycles. The CPU does take dependencies into consideration when going to execute instructions. I think in your example it will do the multiply first then the divide afterwards because the division depends on the result of the multiply. It might queue the instructions in a different order but they do not execute until all the operands are valid. Since the divide depends on the multiply result it wont execute until later.
The core is too large to fit in the FPGA even in its smallest configuration. It is close to fitting but I am not going to try and shoehorn it in. I may end up writing a software emulator for the core. There is an even larger core with 512-bit registers being worked on.
Started working on getting the thing running in simulation.
Wed Dec 10, 2025 6:13 am WWW
It looks like the stripped-down version of the core just might fit (90% full by last estimate). No room for anything else but perhaps a UART. Keyboard controller and text display may also be possible. No room for a DRAM controller though. Will have to use block RAM for memory so no OS.
Altered how MSI interrupts are handled so that 32-bit slave devices could cause MSI interrupts. Previously a lot of information was passed on the response data bus to identify the interrupting device requiring a 64-bit bus. Now there is just a 10-bit index into a device address table that identifies the device. This does limit the number of interrupting devices to 1024 devices per interrupt controller. The system can support 62 QMSI controllers so there is a limit of 62k devices in a system.
The 10-bit index is expanded out to a 45-bit device address using an address table in the QMSI controller. Only the upper 32-bits of the address are recorded in the table since devices are aligned on memory page boundaries (the thirteen LSBs are zero).
Thu Dec 11, 2025 9:20 am WWW
Users browsing this forum: AhrefsBot, alibaba-cloud, CN-mobile-9808 and 18 guests
