actionfingers
Should I buy some sort of kit and start there? Should I find some books on electronics or computer engineering? If so, any recommendations?
Wed Aug 29, 2018 11:17 am |
Welcome! We're told that different people have different learning styles, so maybe a book is what you need, or maybe some video lectures, or maybe a kit to build with. When you say "computer from scratch" I suppose you mean a microprocessor, and some ROM and RAM, and hook up a keyboard and screen? Possibly a good place to start is Grant Searle's projects. If you pick a 6502 project, then there's a healthy community over at 6502.org to help you. If you pick another CPU such as Z80, then the community at retrobrewcomputing might be a good place. We're helpful here, and knowledgeable, but we are not numerous. If you want to understand digital logic, and address decoding, and so on, then Garth's primer is a good place to start - there are lots of links there to more resources. Hope this helps!
Wed Aug 29, 2018 11:23 am |
actionfingers
Wed Aug 29, 2018 11:28 am |
Sounds like a great way to start. Myself, I tend to read a lot. But my first computer was a kit, which I dutifully soldered up, and then re-soldered it because it didn't work, and then it did work. Understanding how it worked came in parallel and afterwards. So I do recommend building an existing design, especially something small and not clocked very fast, and then building on that experience. It's certainly fine to build a system on a breadboard, especially if you take care with the power supply and the decoupling capacitors, and you run at say 1 or 2 MHz clock. Garth's primer - and then, perhaps, searching on electronics stack exchange - will probably answer most questions about safe practices, and debugging. But do ask here, or on another forum, if you get stuck. For myself, I read Horowitz and Hill which was a huge paperback. I still have it. You can get a copy for a tenner, and it probably doesn't matter too much which edition you get.
Wed Aug 29, 2018 11:36 am |
actionfingers
Wed Aug 29, 2018 11:38 am |
Wed Aug 29, 2018 11:40 am |
Joined: Tue Dec 11, 2012 8:03 am Posts: 273 Location: California
BigEd wrote: If you want to understand digital logic, and address decoding, and so on, then Garth's primer is a good place to start - there are lots of links there to more resources. Thanks for the reference, Ed. actionfingers, most of my voluminous site is 6502-oriented, including of course the 6502 primer; but note that the primer also has a lot of material that will apply to most any other 8- or 16-bit processor as well. It is logically organized, and was written to address problems and questions that kept coming up on the 6502.org forum. These are the sections: - Intro: Why a 6502?
- Address Decoding
- Memory Map Requirements
plus: Why 6502 goes low byte first - Interrupt Connections: IRQ and NMI
- 74xx Logic Families and Timing Margins
plus: "Do I Need Bus Transceivers?" and: Static-Handling Precautions - Clock Generation
- Reset Circuits
- What Do I Do With the "Mystery" Pins, SYNC, RDY, S.O., Φ1, MLB, BE, and VPB?
- Construction: Avoiding AC-Performance Problems
- Expansion Buses and Interfaces
- Getting More On a Board
- Answering Wire-Wrap (WW) Questions and Doubts
- What About Custom PC Boards?
- I/O ICs
plus: extra info on 6551 ACIA clocking options - Displays
- Where to Buy 65-Family Parts
- General Steps For A Successful Project
- Program-Writing: Where Do I Start?
what to put in your .ASM file - Debugging
- Tips For Programming the 65(c)02 (some affecting hardware design too)
- Basic Workbench Equipment
- Circuit Potpourri
Happy building!
Thu Aug 30, 2018 8:45 am |
actionfingers
Thanks again guys!
Thu Aug 30, 2018 8:53 am |
actionfingers
Sat Sep 01, 2018 12:16 pm |
Sat Sep 01, 2018 12:25 pm |
actionfingers
Sat Sep 01, 2018 12:28 pm |
actionfingers
Sat Sep 01, 2018 12:32 pm |
. Ah, I see. Note that there's a set of 9 lines for the nine digits of the calculator, and then 8 segment lines for the seven segments and decimal point. So, scan line 9 just means that the right-most digit is presently being driven. What they are not dealing with, yet, is how a '3' is represented, and how it is decoded to the pattern of segments.
Sat Sep 01, 2018 12:43 pm |
actionfingers
Sat Sep 01, 2018 12:46 pm |
. You're welcome! There was a very nice bit in a recent Intro on 6502.org: Quote: I then taught myself machine code from a magazine I had borrowed from an uncle. At first I didn't understand a single sentence from the article. But I believed it had to make sense one way or another, so I just kept rereading the article, probably dozens of times. Later I found out it was the 2nd article in a series and I had missed the introduction of all concepts. I do like the sense of perseverance in that. Indeed, I bought a monthly electronics magazine as my own intro to digital logic, and I think similarly things didn't make much sense at first but reading more and more it started to. (I'd previously had an electronics kit with an excellent manual which had taught me a little of the basics of non-digital electronics.)
Sat Sep 01, 2018 1:03 pm |
