View unanswered posts | View active topics It is currently Mon Apr 29, 2024 9:45 am
Reply to topic  [ 3 posts ]
 PDP8 Extended Arithmetic Element EAE
Here is a rabbit hole for your consideration! The PDP-8 had an optional card set called the EAE for Extended Arithmetic Element. These cards performed asynchronous math calculations as described in the attached screenshot. Better yet, the coding manual and circuit diagrams are available online here:
http://vandermark.ch/pdp8/index.php?n=H ... Arithmetic
http://vandermark.ch/pdp8/uploads/Hardw ... awings.pdf
On the circuit diagrams I see some standard TTL glue logic, counters, multiplexers and some ROMs. I attached a photo of the boards from the links. The circuit diagrams are especially interesting. If you have any other links I'd enjoy seeing them. Thanks!
Tue Mar 21, 2023 10:44 am
Just in case someone follows this link while doing a search... here is a detailed explanation of how the EAE works, as posted by a helpful member over at the Vintage Computer Forum.
http://vandermark.ch/pdp8/uploads/Emula ... AE-ocr.pdf
Sat Mar 25, 2023 11:42 am
The PDP 8/a had floating point hardware option as well, to give full hardware floating point in the mid 70's.
File comment: From bitsavers
MP00057_FPP8-A_Mar76.pdf [6.3 MiB]
Downloaded 236 times
Sat Mar 25, 2023 5:03 pm
Users browsing this forum: No registered users and 32 guests
