AnyCPU
http://anycpu.org/forum/
Black Widow Core
http://anycpu.org/forum/viewtopic.php?f=23&t=902
Page 2 of 2
Author:  oldben [ Sun May 01, 2022 9:13 pm ]
Post subject:  Re: Black Widow Core
Check the typing,
The last fault I found was in a bios library I was revising. A typo in revised branch label,sent me to a random place
in the code. Having had changes just made to the string and printf functions made locating the bug harder.
I am moving away from C strings to a Pascal style string with the first byte indicating length. 0 length is a string
constant that is null terminated. This way I can later impliment a string data type, in the langauge I am developing.
string animal[12]
animal = get a animal name()
if overflow do string error()
if animal = 'duck' print "quack!" -- duck
or animal = 'cow' print "moo!" -- cow
else print "streak! beer! barmaid!" -- default human
fin
I have been finding C strings are too quick and dirty for production work having no length,
Author:  drogon [ Mon May 02, 2022 5:20 pm ]
oldben wrote:
Check the typing,
*cough*
I think you mean BCPL style strings here ;-)
Neither way is perfect and both ways have issues. The BCPL way is limiting although it's not always obvious - writing an editor that supports an arbitrary line length for example...
-Gordon
Author:  oldben [ Tue May 03, 2022 2:36 am ]
-Gordon
I guess with the wider screens one can have 80x132 text windows.
I did it this to way have easy upgrade path, so I can hand port programs
in C like my cross assembler to the language I am using for this machine.
The correct way is type string { int size; int length, buffer[];}
The same could be said for any array type.
We have yet to fix bugs with C strings and we keep getting more and more
versions of text encoding.
Author:  robfinch [ Sat Jul 16, 2022 3:20 am ]
Just looked at this core briefly after leaving it for a while.
For some reason I added SETxx instructions to the ISA when there were already CMPxx instructions doing the same thing. It must have been when I was working away at two different times.
Page 2 of 2 All times are UTC
http://www.phpbb.com/
