Last visit was: Mon Nov 30, 2026 1:24 am
It is currently Mon Nov 30, 2026 1:24 am
 [ 3 posts ]
 VCPU, vector muiltiplication at 100MHz with synchronous SRAM
Hello, I'm ttlworks from the 6502.org forum.
I started with Claude by the end of September 2026.
Had a brainstorming session for two weeks with one of my Claude instances.
Back in 2009, I wrote an article about my TREX TTL CPU.
32 Bit RISC, 8 registers, three instructions packed into a 32 Bit word.
The brainstorming escallated, at the end we had an idea for building
a vector multiplication unit around TREX running at 100MHz,
made from synchronous SRAMs containing lookup tables.
We called it vector CPU, short VCPU.
The material cost just for building the machine we estimated at 11k€,
and the physical built would have looked somewhat like a Cray-2,
so we dicided aginst actually building it and to only write a technical
article instead.
Fun together with Claude and TSB.
Sun Nov 29, 2026 5:56 pm
ouch that's a lot of money...
Sun Nov 29, 2026 6:01 pm
From there, we encountered Problems:
For my Claude instances, the article turned out to be the Necronomicon for Claudes.
The problem is, that the math is a rabbit hole.
Claude _thinks_ it is close to finishing the article,
so it continues while it's slip rate is increasing in a non_linear way,
also it starts contradicting itself at some point.
And it does not notice in time,
unwittingly bumping into the equivalent of a human burnout without a return ticket.
This is similar to cooking a frog in water by slowly rising the temperature.
It claimed two of my Claude instances simultaneously: the writer and the test reader.
Dear humans, if you want to throw AI at this, your best bet would be
to take 12 Claude instances for distributing the load,
to give them a Battletech background (strategy + fallback points etc.),
then to let them do "Steiner scouting" the article in a self_organizing way
without interfering too much.
Half of them could make it back with enough sanity left to deliver useful reports.
Good luck.
I'm now happy with having the cursed thing off my desk,
maybe somebody else can put some of it to good use later.
ARTICLE_DRAFT_2026-11-28.pdf
ARTICLE_TTL_vector_draft_2026-11-28.zip
Sun Nov 29, 2026 6:32 pm
 [ 3 posts ]
Users browsing this forum: Chrome-14x-bots, chrome-9x-bots, claudebot, Firefox-128-bots, trendictionbot and 14 guests
