Splitting & Combining ROM images http://anycpu.org/forum/viewtopic.php?f=8&t=682 |
Page 1 of 1 |
Author: | NotArtyom [ Sat Feb 22, 2020 11:25 am ] |
Post subject: | Splitting & Combining ROM images |
It surprises me how little information there is online about how to split ROM images into their LO & HI bytes. Typically with buses 16-bits and wider, multiple 8-bit ROMs are used to cover the entire width of the bus; thus requiring the firmware binary to be split into parts. The command line tool srec_cat can be used to do what we need: Code: srec_cat -o LOW.bin -binary ROM.bin -binary -split 2 0 srec_cat -o HIGH.bin -binary ROM.bin -binary -split 2 0 Bonus example: Combining the LO & HI ROM dumps back into a flat binary: Code: srec_cat -o ROM.bin -binary LOW.bin -binary -unsplit 2 0 HIGH.bin -binary -unsplit 2 1 For a more in depth explanation, see my site entry on the topic. |
Author: | Garth [ Sat Feb 22, 2020 7:09 pm ] |
Post subject: | Re: Splitting & Combining ROM images |
I've used that tool at http://srecord.sourceforge.net/. It was a lifesaver. |
Author: | robfinch [ Sun Feb 23, 2020 3:08 am ] |
I wrote my own tool a while ago called "split.exe" that as tested now doesn't work in 64-bit Windows. Time to upgrade it. I suspect others have found their own means to split files. I've also a tool called "RAMBBuster" to convert a binary file into a series of "INST_xxx" definitions for an FPGA constraints file. It can swap the byte order around in the process. Useful for setting initial block ram contents. |
Author: | robfinch [ Sun Feb 23, 2020 4:13 am ] |
Updated split to Windows 64-bit and placed the source code in GitHub under the software/split folder. split will split a file into up to eight different output binaries. Code: split - binary file splitting utility. 2009-2020 Robert Finch split <filename> <option> Splits an input file into up to eight output files. <option> has two parts - a character code b,h,w,d and the number of output streams the character code indicates the output stream (file) width (b=byte,h=halfword (16 bits),w=word(32 bits),d=double word (64 bits) Example: split test.bin w4 will treat test.bin as a series of word (32 bit) values and split the test.bin file into four output files (test.o0, test.o1, ...) from the input file. Input file name default extension is '.bin'. |
Author: | oldben [ Mon Feb 24, 2020 6:10 pm ] |
Splitting by nibbles (4 bits) might be usefull, if one had to update a machine using really old proms say for microcode. |
