Last visit was: Tue Mar 31, 2026 5:15 pm
It is currently Tue Mar 31, 2026 5:15 pm
 [ 7 posts ]
 subOctavo: a 3-operand RISC
* subOctavo is a single-thread mutation of Eric LaForest's Octavo 3-operand RISC concept at https://fpgacpu.ca.
* All code, data, and IO "exist" within a single 1024x36-bit addressable space.
* asm.cmd assembles <yourchoice.py> and generates x.hex, the 2-port RAMs image.
* ivsim.cmd simulates subOctavo.prj and generates subOctavo.log.
* Prerequisite development tools:
1) Python3, e.g. https://www.python.org/, to implement the 2-pass assembler that generates x.hex.
2) Icarus Verilog, e.g. http://bleyer.org/icarus/, to define subOctavo and simulate x.hex.
* The characteristic width of the i instruction field is 4 bits.
* The characteristic width of the program counter, and d, a, and b instruction fields is 10 bits.
* The bit aggregate of a 36-bit instruction is {i, d, a, b, 2'b00}.
* The i, a and b 2-port RAMs are initialized with x.hex.
* The i, a and b 2-port RAMs are read from on negative clock edges.
* The i, a and b 2-port RAMs are written to at the d address on positive clock edges.
* The critical path is between the negative and positive clock edges, suggesting a clock duty cycle of < 50%.
* The address 0 is reserved for a safe destination, namely 'trash'. trash might be used as a scratchpad.
* The address 1 is the program counter reset value, namely 'reset', the first instruction of all programs.
* The address 0x3ff points to the read-write parallel output port.
* The address 0x3fe points to the read-only parallel input port.
* The address 0x3fd points to the read-only free-running timer.
* Non-jump instructions treat the a-field as a pointer like the d and b fields.
* Jump instructions treat the a-field as a 10-bit constant (#a).
* Any non-jump instruction with the destination address of trash suffices as a no operation.
* The "standard" subOctavo nop() is {band, trash, trash, trash, 2'b00}, which encodes to 36'h300000000.
* The instruction register and program counter stack are updated on positive clock edges.
* pc[0] refers to the top of the program counter stack, which is the active program counter.
* With a program counter stack register array of [0:7], calls may be nested up to 7 levels.
* Jumps involve 1 following instruction (which will execute) due to the pipeline latency.
* Jumps write 0 to trash.
* 36-bit instruction summary:
add  {4'h0, d,     a, b, 2'b00} d = a + b; pc[0]++
sub  {4'h1, d,     a, b, 2'b00} d = a - b; pc[0]++
mul  {4'h2, d,     a, b, 2'b00} d = a * b; pc[0]++
band {4'h3, d,     a, b, 2'b00} d = a & b; pc[0]++
bor  {4'h4, d,     a, b, 2'b00} d = a | b; pc[0]++
bxor {4'h5, d,     a, b, 2'b00} d = a ^ b; pc[0]++
srl  {4'h6, d,     a, x, 2'b00} d = {1'b0, a[35:1]};  pc[0]++
sra  {4'h7, d,     a, x, 2'b00} d = {a[35], a[35:1]}; pc[0]++
ror  {4'h8, d,     a, x, 2'b00} d = {a[0], a[35:1]};  pc[0]++
jze  {4'h9, trash, a, b, 2'b00} d = 0; if (b == 0) pc[0] = #a else pc[0]++
jnz  {4'ha, trash, a, b, 2'b00} d = 0; if (b != 0) pc[0] = #a else pc[0]++
jpo  {4'hb, trash, a, b, 2'b00} d = 0; if (b >= 0) pc[0] = #a else pc[0]++
jne  {4'hc, trash, a, b, 2'b00} d = 0; if (b < 0)  pc[0] = #a else pc[0]++
jmp  {4'hd, trash, a, x, 2'b00} d = 0; pc[0] = #a
jsr  {4'he, trash, a, x, 2'b00} d = 0; pc[7:2] = pc[6:1]; pc[1] = pc[0]+1; pc[0] = #a
ret  {4'hf, trash, x, x, 2'b00} d = 0; pc[0:6] = pc[1:7]
* By convention, a don't-care field (x) is encoded as 0. See asm.py.
* Zipped subOctavo source is at https://drive.google.com/file/d/1WQC-dlEbdtbmipySzIj6YDEAGJhdybpq/view?usp=drive_link.
* The x-series of .py files reflects the author's subOctavo programming learning curve.
* x1.py crawls out of the primordial goo.
* x15.py solves integer square roots (with remainders).
* Author contact: MyronPlichota@gmail.com.
Sat Feb 22, 2025 5:53 am
quite a remarkable machine!
I suppose the original 8-threaded machine achieved its high performance by getting 8 clock cycles of latency?
Sun Feb 23, 2025 7:40 am
I concur.
Octavo jumps do not involve any delay slots, unlike most other 3-operand RISCs.
However, generating 8-threaded code to exploit this strength is a black art.
Sun Feb 23, 2025 2:09 pm
Yes, it seems to me the designer did feel that the clever hardware design had forced a need for extremely clever software.
I don't quite understand the A and B parts of memory - is it really true that each of the two operands must come from different parts of memory?
Sun Feb 23, 2025 4:57 pm
The i, a, and b 2-port RAMs are separate instances of the 1024x36-bit ram_2p_nr_pw module.
The i, a, and b RAMs write addresses are driven by the instruction d field.
The i RAM read address is driven by the program counter.
The a RAM read address is driven by the instruction a field.
The b RAM read address is driven by the instruction b field.
Mon Feb 24, 2025 4:05 am
Aaah - so this is really a single logical memory implemented as three memories with the same contents?
Mon Feb 24, 2025 8:20 am
Just so!
Mon Feb 24, 2025 10:22 am
 [ 7 posts ]
